TOPIC: 59 Super Seahorse wiring
59 Super Seahorse wiring 10 years 6 months ago #116033
Is the external plug for motor control still available? I've been looking online and I find internal harnesses but not the boat side. Also, I have wiring diagrams but I'm not sure of which pin on the connector goes to what. I assume that the largest pin goes to the starter, but I don't know if I'm interpreting the others correctly.
Re:59 Super Seahorse wiring 10 years 6 months ago #116034
Is this correct?
Re:59 Super Seahorse wiring 10 years 6 months ago #116055
Besides finding a used harness, they are not available. A fellow in Canada offers a very nice reproduction: nymarine.ca/wiringharness.htm
Re:59 Super Seahorse wiring 10 years 6 months ago #116060
Dave, if you have a multimeter/ohm meter it's easy to just trace the wires. Put one probe on the pin and touch the internal connections on the motor until you find continuity.
Re:59 Super Seahorse wiring 10 years 6 months ago #116066
I guess I'll keep searching for a used one. That's a nice looking harness, but almost equals what i paid for the motor.
Re:59 Super Seahorse wiring 10 years 6 months ago #116067
Multimeter sounds like a simple solution. I'll give that a try.
Re:59 Super Seahorse wiring 10 years 2 months ago #119959
Not sure if this is of use to anyone else, but I thought I'd share what I found. Far left is ground and plug mount. Large one in the center is hot to starter. Top left goes to vacuum cutout. Top right goes to generator. Row below starter, left goes to generator, right goes to mercury switch. Bottom row, left goes to magneto, right goes to choke.
Re:59 Super Seahorse wiring 10 years 2 months ago #119970
Dave, you nailed it. Gotta clean up those pins though. I found that if you wrap some steel wool around a small stick you can poke around and clean 'em up pretty good, do the same with the female end, I then blow out the steel fibers, wipe down with some type of thinner and coat them with dielectric grease. Regular Vaseline works in a pinch.
Re:59 Super Seahorse wiring 10 years 2 months ago #119975
I've got the plug disconnected from the motor right now so cleaning the pins should be easy. Unfortunately, I don't have the female end, so unless I can find a used one, I'll just make something up.
1962 Scott - last chance!
( / Parts / Miscellaneous)
04-14-2026
Attwood 6000-09 Green & Red Side Light
04-14-2026
We have 4978 guests and no members online
