TOPIC: Starts and runs but no power.
Starts and runs but no power. 11 years 1 month ago #115181
  • Tomahawk
  • Tomahawk's Avatar Topic Author
This is the same 66 100hp johnson I want change to electronic ignition. I replaced points and condenser. Spark is much improved but seems like half the motor is running. any suggestions on how to proceed?
Re:Starts and runs but no power. 11 years 1 month ago #115182
Have you checked to make sure you're getting spark to all four?
Re:Starts and runs but no power. 11 years 1 month ago #115184
  • Tomahawk
yes I have spark on all four plugs. had a great reminder as I tried to pull a plug wire as it was running. very energizing.
Re:Starts and runs but no power. 11 years 1 month ago #115219
  • Tomahawk
so the answer appears to be - Don't switch the plug wires! #2 and #4 were swapped. Don't know how or when but it doesn't work well. Real test will come wednesday when I can take it out to play.
Re:Starts and runs but no power. 11 years 1 month ago #115225
  • Tomahawk
So what potential damage did i do by firing the 2 cylinders at the wrong time?
Re:Starts and runs but no power. 11 years 1 month ago #115258
  • Jim L
  • Jim L's Avatar
I'm going to say you didn't hurt it. I did the same thing to the '63 johnson when I tuned it up for the first time after I had it rebuilt in '83. The "mechanic" and I use that term loosely installed the water jacket cover on the port head up side down and me being very new to messing with these old engines put # 2 wire to #2 spark plug or where the hole had a #2 beside it. Not a good running motor at all after that :laugh: :laugh: .. So I carried it to another mechanic and he straightened it out. So I know how it feels for sure. It ran just fine after that. :) jim
We have 8220 guests and no members online
