TOPIC: 1973 'Rude 135 compression
1973 'Rude 135 compression 11 years 2 months ago #114554
Have a chance to pick up a 1973 135hp for next to nothing. Compression is 150 and then 65 - 55 - 60. With three out of four with bad readings could it be rusty reeds? Motor has been sitting for beau coup years. I have reeds that would fit it.
Guessing here, but with good compression on one cyl does that rule out bad crank case seals??
Opions????
Re: 1973 'Rude 135 compression 11 years 2 months ago #114555
I would worry bad rings / scored bore.... Only way to tell is pull it apart.
Re: 1973 'Rude 135 compression 11 years 2 months ago #114557
  • VinTin
  • VinTin's Avatar
Reeds don't play a role in compression, so it's not the reeds.
www.animatedengines.com/twostroke.html
Re: 1973 'Rude 135 compression 11 years 2 months ago #114558
ok, so it's a parts motor. the starter alone is worth more than I would pay. The underling reason is because it has tlt which I need for my meteor :laugh: I know the alum is $35., did that with a 75hp last month.
Already told the admiral I was going to pick it up.
Time to create page: 0.081 seconds
We have 12957 guests and no members online
