TOPIC: 1971 Johnson 50hp -fuel pump?
1971 Johnson 50hp -fuel pump? 11 years 3 months ago #113650
Hello.
I have a 1971 Johnson 50hp. I've used it the last couple of summers. This year I started it up a couple of times in the driveway briefly. Replaced the throttle cable and I wanted to test it out. I launched the boat and attempted to start it. It ran for a few seconds and died. I haven't been able to start it since.
I replaced the fuel lines with clear ones so that I can see if its moving. The fuel was not going past the fuel pump. A friend rebuilt it for me with a kit. I reinstalled it and still no start. I removed the line from the carburetor and fuel just dribbles out as I crank the motor.
How much fuel should shoot out of this line from the pump?
There is lots of spark and compression. Bowls on carbs are empty.
Thanks.
Re:1971 Johnson 50hp -fuel pump? 11 years 3 months ago #113656
Take the pump apart again and make sure the passages aren't blocked some how. Make sure they all get blown out. If you had an old hose breaking down a small piece could have come off and gotten lodged in there.
Re:1971 Johnson 50hp -fuel pump? 11 years 3 months ago #113669
You replaced the suction fuel line as well?
Re:1971 Johnson 50hp -fuel pump? 11 years 3 months ago #113683
Hi guys.
Thank you for taking the time to respond to my issue.
I Replaced every fuel line between the tank and carburetor. Fuel was still not getting into the carburetor. I took apart the fuel pump that my friend rebuilt for me and I found that he put one of the springs in the wrong spot (after I searched for a diagram online).
Fuel still wasn't going into the carbs! I took off both carbs and found that the float valves were stuck in both of them!
I put it all back together and it started right up. I was so relieved that I found the problem. :laugh:
Re:1971 Johnson 50hp -fuel pump? 11 years 3 months ago #113685
Congrats to you!!!!!!!!!!!!!!!! Now go have some fun - it's the weekend.
Re:1971 Johnson 50hp -fuel pump? 11 years 3 months ago #113701
Good job, congrats, now go run her!!!!!!!!!
We have 12696 guests and no members online
