TOPIC: 1961 Starflite III Start Issues
1961 Starflite III Start Issues 11 years 3 months ago #113347
  • dspeck
I bought this engine in 2010 as part of a Glasspar G3 restoration project. The project took longer than I anticipated, but I suppose that's not news to anyone but me. I ran the engine on a stand several times during the project. It always started quickly and idled nicely. I finally put my boat into the water on July 28th and it started right up with an even idle. I ran it around the lake for about 20 minutes just to see how it handled. When I went to dock, the engine stalled and I could not get it to restart. The starter spins, the engine cranks, it fires once but doesn't start. Trying it again, same result, no matter how many times I try it. Gas is fresh mid-range with Pennzoil 2 stroke mixed 32:1. I've just read 50:1 is now preferred and will adjust to it when I fill the second tank.
I'm wondering is the starter may be worn out, but this is the first starting difficulty I've experienced. For the 20 minutes I ran it, it purred at both half throttle and full throttle. Seems like running it would only make it easier to restart, all things considered.
I will appreciate any help/advice anyone can offer.
Doug
Re:1961 Starflite III Start Issues 11 years 3 months ago #113353
Doug, if the starter turns over and the motor turns it's not a starter problem. If the engine sat as long as you say, I'm thinking a fuel delivery problem, old fuel, fouled plugs etc. Check the fuel pump intake screen/filter, make sure it's not filled with dirt. Pull the spark plugs and check the condition. If they are black and oily I would get new ones and use the fresh 50;1 mix. Ethanol gas is a no no no. It will eat away at the rubber fuel lines and fuel pump diaphragm and put little pieces of rubber in your carburetor. Take a peek inside the fuel tank as see if anything is hanging around the bottom like water.
Doesn't sound like a spark/ignition problem by your description.
Cal
We have 12914 guests and no members online
