TOPIC: Aluminum repair
Aluminum repair 15 years 1 month ago #43434
  • thetudor
  • thetudor's Avatar Topic Author
I know nothing about working on an aluminum boat, but since I'm the boat guy, I got the call. I have a friend who has an old (not classic, just old) 12 ft aluminum boat the she uses to take her nieces and nephews fishing in a pond. She called be and said that it sprung a leak and found a crack near a seam when she turned it over. I was asked to come fix it, since I'm the boat guy. Any thoughts on how to seal this up?
I have not seen it yet, so I don't have many specifics.
Todd (aka thetudor)
1964 Custom Craft Aqua Ray
1959 Glastron Seaflite
1959 Tomahawk Spirit
Re:Aluminum repair 15 years 1 month ago #43448
i think i fixed a rivet hole with jb weld more than 20 yrs. ago. i just mixed up a blob and stuck it on. its still there. ron
Re:Aluminum repair 15 years 1 month ago #43661
  • Heather
  • Heather's Avatar
TIG....
Mrs Spookeay Bird
Re:Aluminum repair 15 years 1 month ago #43697
What Heather said. Don`t even try the aluminum weld stuff that you can supposedly do with a propane torch. I have done several types of welding in 45 years of working and the only thing I had left after trying this stuff is a puddle of aluminum slag.
A TEMPORARY fix is to put on some red or black silicone from the auto parts store after hard brushing with a steel wire brush.
Re:Aluminum repair 15 years 1 month ago #43704
  • thetudor
I'm not a welder and I'm not going to start now. I want to do a temporary fix that will get through the next 4 weekends and then figure out a strategy.
Perhaps the best solution is to find a new boat on CL.
Todd (aka thetudor)
Re:Aluminum repair 15 years 1 month ago #43715
Another quick fix is to find a thick aluminum tape. If the metal is flat you can patch it with that. It is only temporary and if you get oil on it the tape will turn loose.
Re:Aluminum repair 15 years 1 month ago #43721
  • Neil
  • Neil's Avatar
The original post was that this is a woman who is taking kids out in the boat.
Safety is paramount out on the water.
Take it to a certified welder and have the repair done correctly and it will the best thing you can do for them, concerning the boat.
Neil
Neil and Mary Ousnamer
Re:Aluminum repair 15 years 1 month ago #43746
-LUMIWELD
The stuff that you use with a propane torch or oxy-acetalene ( for bigger pieces )---works like a charm.
Re:Aluminum repair 15 years 1 month ago #43747
From Lumiweld's website;
www.aluminumrepair.com/boat-repair.htm
Re:Aluminum repair 15 years 1 month ago #43748
being it is not a vintage I would use a piece of aluminum 5200 and some blind (closed end) pop rivets.
Cut and bend the aluminum to cover the crack...Then drill a hole into the boat at each end of the crack as to stop it from running
Lay the aluminum over the crack and drill a few holes through as to rivets in place(I do 4 ..one on each corner and place a rivet in the hole to hold the aluminum in place while I drill the others) . Then remove the aluminum add 5200 and replace the aluminum
Rivet in place and drill more holes (about a inch a part) and rivet ..let set over night
www.hansonrivet.com/w22.htm
Re:Aluminum repair 15 years 1 month ago #43777
  • Paul
  • Thank you received: 7
I used auto body seam sealer on my Feathercraft and it worked great. It's tough stuff.
Re:Aluminum repair 15 years 1 month ago #44152
please forgive my hijack,but has anyone used lumiweld to fill pits in aluminum,then sand and buff,my flying fish has some pitting in the aluminum.
sorry about the hijack todd,john
Re:Aluminum repair 15 years 1 month ago #44372
It will " age " to a different shade of aluminum , as in much darker.
Time to create page: 0.089 seconds
We have 6217 guests and no members online
