TOPIC: cause of low compression
cause of low compression 6 years 10 months ago #141423
Looking at a '77 Evinrude 140hp but has low compression in all four cylinders, 75.80.etc. What would cause this to be in all four?
Maybe running with no mix? Over heat and warped heads?. Can get it really cheap with working tnt. Everything else is good.
Opins please.
cause of low compression 6 years 10 months ago #141425
OMC never publicized compression. Only that they should be within 10%
Cold engine, no back pressure & large exhaust ports will all cause low compression at cranking speeds. My old 90 DU only reads 60 or so.
cause of low compression 6 years 10 months ago #141426
Thanks, Now I'll probably get another motor to hang on the wall. Nothing like having an over powered backup for a 15 footer.
We have 5482 guests and one member online
