TOPIC: 1966 Evinrude Starflite 100-S Tach Question
1966 Evinrude Starflite 100-S Tach Question 13 years 9 months ago #10716
  • DelRio62
  • DelRio62's Avatar Topic Author
Does anyone have any advice on an appropriate tach for this engine; how it would be installed and a possible location to buy one?
As I'm trouble shooting and for future info, I suspect having one would assist,
Matthew
Re:1966 Evinrude Starflite 100-S Tach Question 13 years 9 months ago #10983
If the engine uses a distributor with points and a coil, just buy a tachometer that will work on a V8 car engine. Follow the instructions and it should work great. Be sure the tach is set for 8 cylinders, not 4 or 6. A 4 cylinder 2 cycle has the same number of firing impulses per revolution as an 8 cylinder 4 cycle engine.
If your engine has the electronic ignition, you will have to find a vintage tach designed to work with that motor. Nothing new is available that will work with the solid state ignitions from that era.
Re:1966 Evinrude Starflite 100-S Tach Question 13 years 9 months ago #11199
  • DelRio62
Bruce,
thanks for the advice, sounds like an automotive tach will do it,
Matthew
Re:1966 Evinrude Starflite 100-S Tach Question 13 years 9 months ago #11201
Hey Bruce,
Just asking, an alternator (12pole) tach won't work on that motor?
Re:1966 Evinrude Starflite 100-S Tach Question 13 years 9 months ago #11270
This in not your year motor but most of it is the same as your. Just thought you can use.
www.theoldglassboats.com/TOGB/outboards/1960-evinrude-starflite-75/
Mike aka pathfinderz1
Re:1966 Evinrude Starflite 100-S Tach Question 13 years 9 months ago #11336
  • DelRio62
Mike, Thanks - love the cowing on that motor - very futuristic - ended up being more rounded in the 100 series,
Appriciate the link,
Best,
matthew
Time to create page: 0.186 seconds
The Pink Lady
The Pink Lady
05-02-2024
Gator 9" wheels Wanted
1969 Stern Craft Boat 19'
04-08-2024
We have 4964 guests and 2 members online
