TOPIC: Help I D prop
Help I D prop 13 years 5 months ago #63865
I have 2 Michigen props and need to know the pich. They are for my Homelite Numbers PS 76
Mike aka the pirate
Re:Help I D prop 13 years 5 months ago #63915
  • 4stroke
  • 4stroke's Avatar
Mike,
From an earlier post I asked the same thing and HandyAndy responded:
This is from a 1969 Michigan catalog, all are for the Homelite/Bearcat:
PS72 - aluminum, 3-blade, 11.5x13, 14 to 16' Boats, light loads
SMC620 - bronze, 3-blade, 11.5x13, 14 to 16' Boats, light loads
PS71 - aluminum, 3-blade, 11.5x12, 14 to 16' Boats, all loads, skis
SMC628 - bronze, 3-blade, 11.5x12, 14 to 16' Boats, all loads, skis
PS73 - aluminum, 3-blade, 11.5x11, 16 to 17' Boats, all loads, skis
SMC626 - bronze, 3-blade, 11.5x11, 16 to 17' Boats, all loads, skis
PS74 - aluminum, 3-blade, 11.5x10, 17 to 19' Boats, all loads, skis
PS75- aluminum, 3-blade, 11.5x9, 20 to 24' Boats, one engine
PS76 - aluminum, 3-blade, 11.5x8, cruisers, houseboats, sailboats
SMC629 - bronze, 3-blade, 11.5x8, cruisers, houseboats, sailboats
AMC712 - aluminum, 4-blade, 11.5x8, cruisers, houseboats, sailboats
Dick Johnson
1989 16ft Sylvan
'58 Johnson 5.5
'72 Johnson 6.0
'61 Homelite
'64 Johnson 18
'65 Homelite 55
'66 Homelite 55
'68 Bearcat 55 (3)
'70 Bearcat 55 (2)
'71 Bearcat 85 (Sold)
Re:Help I D prop 13 years 5 months ago #63936
Thank you
Looks like these will work great for trolling.
Mike aka the pirate
Re:Help I D prop 13 years 5 months ago #63948
  • 4stroke
  • 4stroke's Avatar
You're welcome. You'll just have to watch your top speed and make sure you don't over rev it. I got two of those also with one of the last engines I bought.
Dick Johnson
1989 16ft Sylvan
'58 Johnson 5.5
'72 Johnson 6.0
'61 Homelite
'64 Johnson 18
'65 Homelite 55
'66 Homelite 55
'68 Bearcat 55 (3)
'70 Bearcat 55 (2)
Re:Help I D prop 13 years 5 months ago #64005
I'm using an 8" 4 blade on the pontoon. I might go to a 9" 3 blade ;)
Re:Help I D prop 13 years 5 months ago #64024
I just got me a tach hooked up so i can watch the rpm's. Also got one hooked up on my buddys G3 with the Bear Cat on it. Running a 13 picth on that one.
mike aka the pirate
Re:Help I D prop 13 years 4 months ago #65350
Not to jack someone elses thread here but I was looking at my prop today while doing some adjustments and these numbers dont seem the same as what some of you have.
90852-11-B
Im wondering if this is why I'm not getting to my wot RPM.
Nick
1961 Uniflite 19' Express, Bearcat 55 powered
1975 Chris Craft 25' Tournament Fisherman, Twin 181 FL inboard
Re:Help I D prop 13 years 4 months ago #65378
  • billr
  • billr's Avatar
that's just the factory stamped equivalent of a PS Michigan, made my Michigan for Homelite/Bearcat.
11" pitch.
If you are running a single on a 19'er I think you want a 9, 10 max, but the tach will tell the story better than any guess.
Re:Help I D prop 13 years 4 months ago #65424
Switched from 8" 4 blade to 9" 3 blade on my pontoon. Seems to be doing alright. Hope to hook up a tach soon. That will tell the real story. :)
Re:Help I D prop 13 years 4 months ago #65448
Well it looks like I have a 10 pitch in the boat so I will try that one tomorrow. I have a couple more in storage so ill have to see what those ones are.
How did you like the 4 blade on your pontoon? I was toying with the idea of running one on my Uniflite but not sure if it would be right or not. I am also going to install a tach shortly to see just what i'm getting rpm wise.
Nick
Re:Help I D prop 13 years 4 months ago #65476
The 4 blade works fine. I plan on using that if I have a pontoon full of people. Usually just two of us on it. Cruise about 3-4MPH B)
Re:Help I D prop 13 years 4 months ago #65535
Switched to the 10 pitch and with a light load i got 4900 rpm and 22 mph. Not too bad for a big boat.
Nick
Re:Help I D prop 13 years 4 months ago #65572
  • 4stroke
  • 4stroke's Avatar
Sounds like Bill's suggestion of a 9 pitch would be perfect.
Dick Johnson
1989 16ft Sylvan
'58 Johnson 5.5
'72 Johnson 6.0
'61 Homelite
'64 Johnson 18
'65 Homelite 55
'66 Homelite 55
'68 Bearcat 55 (3)
'70 Bearcat 55 (2)
Re:Help I D prop 13 years 4 months ago #65613
Yep I'm thinking so. Going to have to see what I have. But I am going to install the second motor here in a week or so, so then I wonder if the 10 pitch would be better for the twin setup?
Nick
Re:Help I D prop 13 years 4 months ago #65614
  • billr
  • billr's Avatar
Twins, cool! Had them on my 18C Power Cat.
Just came in from dinking around with the 14T with short shaft 55.
It will be interesting to see what speeds you get with the twins.
Can't beat the price.
Flying Scott 60
10-02-2025
1964 Aristo-Craft Funliner
09-12-2025
We have 5625 guests and one member online
