TOPIC: I belive I need a Bear Cat starter
I belive I need a Bear Cat starter 13 years 3 months ago #62349
I have gone through thls starter 4 times now. Changed the top bushing so its not draging. But for some reason the starter had no power. Just did a compression check WITh the plugs out and it ran the battrie down plus got hot.
Now has anybody out there got a good starter for a ressonable price?.
Mike aka the pirate
Re:I belive I need a Bear Cat starter 13 years 3 months ago #62382
Check with Billr. I believe he can sell you just the motor or the brushes or whatever you need. Bearcat 55.com. Did you do a systems check to see if it was the motor?
Re:I belive I need a Bear Cat starter 13 years 3 months ago #62388
its the starter motor have checked all conections. Not the first start I have worked on.
Mike aka the pirate
Re:I belive I need a Bear Cat starter 13 years 3 months ago #62432
I'm not sure exactly what Billr has, but, I'm sure he can set you up with something. I'm pretty sure you can by just the motor. I work on cars and airplanes as well. Sucks when it's the starter.
Re:I belive I need a Bear Cat starter 13 years 3 months ago #62441
Looks like I just might have to check with Bill. Was hoping someone on here might have on for cheep. Money is short.
Mike aka the pirate
Re:I belive I need a Bear Cat starter 13 years 3 months ago #62442
Believe me, I know. These outboard motor parts are expensive. Here's what I did. There's a an auto parts store that I go to where a friend of mine, George, works. If I need something, like that motor mount I made, I go there to se if they have specs on what I need. If you took you starter motor to an auto electrical shop that can rewind the motor, it might cost less. Aside from the design of the Bearcat parts, the common parts, bearings, bolts, seals are standard in the industry. The starter you have, might be the same motor they use , for example, VW, or Ford. By the way, that motor mount cost 5 bucks to make. If you'd like, since my starter is off, I'll take it to Hap's and see if they have a crossover and let you know.
Re:I belive I need a Bear Cat starter 13 years 3 months ago #62443
Hey thanks if you can do that maybe I can one off samll car motor here
Mike aka the pirate
Re:I belive I need a Bear Cat starter 13 years 3 months ago #62452
  • billr
  • billr's Avatar
Morning guys,
There are 3 different starters used on the 55.
I need pictures and a phone call to supply starters or parts for same.
Mike, I replied to your email.
Re:I belive I need a Bear Cat starter 13 years 3 months ago #62456
I've got a rebuilt Bearcat F series, and enough spare parts to build another Homelite with parts left over - for sale for $1200. I'm selling off all my old stuff and concentrating on one boat and one motor! :S
Blest boater
Re:I belive I need a Bear Cat starter 13 years 3 months ago #62479
There's one at www.vintageoutboardparts.com . It's $40.00, but, it's used and it says it's welded. I'm not sure about this one. Sounds like Bill has one for you. Thing is, if you buy a used one and that one burns up, your SOL. On something like that, you want a good starter, especially if your out somewhere and that starter doesn't work. My friend George at Hap's auto says that to rebuild a marine starter is mucho bucks. I know these parts are not cheap. I'm living on a fixed income and sometimes I have to wait awhile to get something I want. But, Bill will stand behind his stuff.
Re:I belive I need a Bear Cat starter 13 years 3 months ago #62480
  • billr
  • billr's Avatar
Mike, just got home and heard your voice mail.
Go ahead and call on the one Craig found above.
Re:I belive I need a Bear Cat starter 13 years 3 months ago #62490
Hey Bill I went to the trouble to send you pix of the starter motor and called. I would at least like to talk to you about price.And sense there are 3 differnt motors I want the right one.
Mike aka the pirate
Re:I belive I need a Bear Cat starter 13 years 3 months ago #62505
  • billr
  • billr's Avatar
Ok I'll call you
The starter below is the correct starter for your motor.
Here's the link:
www.vintageoutboardparts.com/shop/index.php?main_page=product_info&cPath=61&products_id=2444
Re:I belive I need a Bear Cat starter 13 years 3 months ago #62506
Thanks Bill I ordered that starter and we will see how good it is.
Mike aka the pirate
Time to create page: 0.068 seconds
We have 2480 guests and one member online
