TOPIC: Spark Plug Gap
Spark Plug Gap 9 years 10 months ago #114928
  • WizardIII
  • WizardIII's Avatar Topic Author
Got a Bearcat 55. Could someone remind me what the plug gap is with the Pertronix ignition? Can't find the info.
Steve
Re:Spark Plug Gap 9 years 9 months ago #114969
  • WizardIII
OK, finally found a 3 year old post from '4stroke' that says after installing the Pertronix unit he gapped the plugs at .040". Is that the general consensus? Yes/no?
Steve
Re:Spark Plug Gap 9 years 9 months ago #114977
That doesn't sound unreasonable Steve, I think "normal" gap is usually around .035".
Re:Spark Plug Gap 9 years 9 months ago #114993
  • WizardIII
Well, it's been running fine at .040 but besides looking like I gapped them with a box nail the plugs were on the black side. Book says .025 with stock points so maybe I'll split the difference.
Re:Spark Plug Gap 9 years 9 months ago #114997
Black wet or black dry? Wet would likely be oil consumption and dry would be running rich (too much gas).
Re:Spark Plug Gap 9 years 9 months ago #114999
I posted this same answer on another site, but will share it here too, it's my own two cents worth.
Spark plug gap is more determined by the coil output. If you still run an original style coil with the resistor wire, the gap needs to be 0.25. If you run a 12v high output coil, you can increase the gap to 0.40.
Dave Riker
Re:Spark Plug Gap 9 years 9 months ago #115126
  • WizardIII
Mark,
Black dry so I plan on playing with the carbs a bit also.
Dave,
Good info on the coil. It looks old so I think it's original. Have to check on that.
Thank you both for your input.
Steve
1984 Switzercraft 20SC
1969 Mercury 1250
1969 Mercury 1250
06-23-2025
1959 Delaney Powercat Catamaran Vintage Full Restoration 14'
06-23-2025
We have 5532 guests and no members online
