Print
Description
Older Mercury 35HP Outboard Motor. It runs good but needs the lower gear unit bearing replaced, as it had milky gear oil. i have the new part but do not have the tools to do it. the serial number is OB394313. the cables are about 12 ft i think and the wire harness about that too in a 14 -15 ft boat. it is still on the boat so you can test run it it. I have the propeller but it is missing the rubber insert.
Carry
Used
Contact
mercury outboard 35 hp runs needs lower unit bearing w/contrmercury outboard 35 hp runs needs lower unit bearing w/contrmercury outboard 35 hp runs needs lower unit bearing w/contrmercury outboard 35 hp runs needs lower unit bearing w/contr
We have 6857 guests and one member online
