  • 2
TOPIC: Need to identify my winter project
Re: Need to identify my winter project 12 years 9 months ago #83763
hodgify,
WELCOME ABOARD.
NEVER seen one of those. = NIFTY boat.
Re:Need to identify my winter project 12 years 9 months ago #83768
luv that boat...a cat with a center keel. needs a shorty windshield. ron
Re:Need to identify my winter project 12 years 9 months ago #83774
Very cool, never seen that hull design before.
Re:Need to identify my winter project 12 years 9 months ago #84096
  • hodgify
  • hodgify's Avatar Topic Author
Got Email from Humber Boat company and they said it was not a Jewel. In the late sixties early seventies they say up here in Ontario Canada boat companies would spring up make a couple hulls and then disappear.Is there any way to search these old companies ?
Re:Need to identify my winter project 12 years 9 months ago #84111
Neat boat, sorry we can't be of more help. Best thing to do is post photos everywhere you can on the 'net. I suggest the forum at Scream and Fly- lots of knowledgeable and long-time outboard boat racers there who may recognize your go-fast boat:
www.screamandfly.com/forum.php
Re:Need to identify my winter project 12 years 2 months ago #92482
  • hodgify
I have been working on this hull as much as I could with the cold winter we have had. Now its time to kick it in gear. I have been grinding the bottom and have removed all old repairs stress cracks and any thing else I found wrong , my question is what is the best to use to fill stress crack areas I will be using epoxy resin.
1. Should I use fibre glass mat to fix stress crack areas or can I mix 1/4 milled fiber and spread in low areas and
2. Seeing that I have sanded the hole bottom with a 40 grit paper can I put one to two layers of thin 7781 glass with epoxy over the hole bottom , will it stick to the old gell coat.
Heres some pictures
Re:Need to identify my winter project 12 years 2 months ago #92483
  • hodgify
Heres another picure
Re:Need to identify my winter project 12 years 2 months ago #92498
Great to see your making progress. I know the glass will stick to what you've ground down but not sure if it will stick to the gelcoat. i would assume it should but other's much smarter than i when it comes to glass repair will pipe up.
Re:Need to identify my winter project 12 years 2 months ago #92508
Looks like you're making some great progress there, are you sick of sanding yet? LOL
1. Unless you've got some severe damage we're not seeing here, I'd stick with milled fiber and resin to fill damaged areas. Follow up with some quality marine glazing putty for the final smooth finish.
2. As stated in #1, I'd avoid adding extra layers to the outside if it were me. (I did add some layers of heavy biaxial to the inside of my hull, laid in between and over the stingers.)
You mentioned using epoxy resin, so you'll want to check with the mfg'r. to make sure you don't have compatibility issues with your choice of re-finish materials (paint, gel coat, etc.).
I'm no expert, just sharing what I've learned from those who are around here. Hope this helps, just my two cents worth........ ;)
Re:Need to identify my winter project 12 years 2 months ago #92561
  • hodgify
Thanks for the advice , but tonight they are calling for snow so every thing is on hold for a few days . I think I might try a test piece of glass and resin on the gell coat to see how well it sticks.
Re:Need to identify my winter project 12 years 2 months ago #92575
  • frog
  • frog's Avatar
  • Thank you received: 3
the glass should stick just fine, if you sand it first to get a ruff finish, the gel coat stuck to the glass on the other side. just my 2 cents. frog
Re:Need to identify my winter project 12 years 2 months ago #92581
I may be wrong but if I remember right you use vinylester (sp) if your going to gelcoat but if you use epoxy you'll have to use paint as the gelcoat won't stick to epoxy resin.
Re:Need to identify my winter project 12 years 2 months ago #92609
  • hodgify
The plan is to use epoxy paint , specifically Awlgrip epoxy paint . I have gotten a few gallons of slightly expired aircraft paint and primers from work,just need to by hardner.
Re:Need to identify my winter project 12 years 2 months ago #92611
hodgify,
Since you're going to use epoxy paint, I'd also use epoxy resin/hardner, thickened with agricultural/pulverized (from the farm supply store) to "whipped cream consistency" & "peanut butter" for everything else.
(One pound of lime will last you a LONG time as a thickener, works GREAT & it's CHEAP. =====> I LIKE CHEAP.)
Re:Need to identify my winter project 12 years 2 months ago #92853
  • hodgify
got all the bad spots filled with a mixture of milled glass and carbon fibre , a few spots I used some mat because they were fairly big spots, a little harder to soak the epoxy through the mat but looks ok.
Re:Need to identify my winter project 12 years 1 month ago #93279
  • hodgify
I got all the spots that I filled with milled fiber sanded smooth and put two layers of a 7500 cloth over the big area repair.
Re:Need to identify my winter project 12 years 1 month ago #93281
  • hodgify
sorry last picture was after I started to spread filler to the hole bottom . Hope to get it all sanded and prime the bottom next weekend.
Heres the picture with glass repair
Re:Need to identify my winter project 12 years 1 month ago #93302
Looking good, keep 'em coming!
Re:Need to identify my winter project 12 years 1 month ago #94138
  • hodgify
Spent all last week sanding the bottom of the hull and transom , sprayed a guide coat of flat black paint and then used a long board sander to get it all straight , should be smoother than when it was new. If anybody new looking can identify hull let me know?
Re:Need to identify my winter project 12 years 1 month ago #94139
  • hodgify
Today I got to apply three good coats of epoxy primer to the bottom . Hope to sand and fill any bad spots this week .
Re:Need to identify my winter project 12 years 1 month ago #94140
  • hodgify
One more of the transom
Re:Need to identify my winter project 12 years 1 month ago #94149
She's looking great so far, keep up the good work!
Re:Need to identify my winter project 12 years 1 month ago #94166
Hi,
Certainly an interesting hull, and your work appears to be really nice. As I am curious, what outboard do you plan to install?
Regards,
Joe
www.fergusonpoolemarine.com
Profile Picture:
Re:Need to identify my winter project 12 years 1 month ago #94215
  • hodgify
Hi Joe I have a rebuilt 1988 60hp Evinrude with tilt and trim that I will be putting on it.I also made an adjustable motor mount for it .
Re:Need to identify my winter project 12 years 1 month ago #94216
  • hodgify
Heres a picture of the jack plate I made
Re:Need to identify my winter project 12 years 1 month ago #94226
Excellent work on the plate!!!!!!!!
Re:Need to identify my winter project 12 years 1 month ago #94249
Hi,
Thank You for sharing, and I too appreciate the jack plate. What are you doing for a propeller if you are mounting (the outboard) pretty high? We recently added these 4-blade aluminum propellers, but it would be costly to mail to Canada.
Regards,
Joe
Profile Picture:
Re:Need to identify my winter project 12 years 1 month ago #94258
  • hodgify
I do plan on using a four blade prop . For this year I will probably just experiment with three blades. Seeing that nobody knows anything about this hull everything I do is an experiment. No plan to jack the motor until I see how it goes. This is going to be my play toy at the cottage as I have a small 15ft bass boat and a 14ft aluminum with 15hp for fishing .
Re:Need to identify my winter project 12 years 1 month ago #94413
Great boat! Anybody seen one like my new project? cannot find pics of anything like it anywhere, no mfg label but it says Vanguard on steering wheel.Let me know if anybody has an idea, thx
Re:Need to identify my winter project 12 years 1 month ago #94561
  • hodgify
Hi Surferjunkie sorry I have been up north to open cottage ,just got home. Great looking boat ,almost looks like a glasspar G3 . You should start a new thread , I am sure there is somebody here that will recognize it . But as every body here says more pictures would be nice. Good luck with the rebuild.
Re:Need to identify my winter project 12 years 1 month ago #94572
Thanks, yes, you are correct it is a G3. Kinda sad that somebody removed the mfg info tag, but now at least i know what i got and hope to get her back on the water in July. Thanks for your reply!
Re:Need to identify my winter project 12 years 4 weeks ago #94936
  • hodgify
Well using my $12.00 Harbour Frieght spray gun I was able to get 3 good coats of awlgrip poly down . Have not sprayed any thing big in 10 years so I think it looks pretty good. Only problem is either I have alittle fish eye or solvent pop ,good thing its the bottom and nobody will see it.
Re:Need to identify my winter project 12 years 4 weeks ago #94938
  • frog
  • frog's Avatar
paul, if the top turns out that nice, you will have one nice looking boat, you did good, be proud buddy. frog
Re:Need to identify my winter project 12 years 4 weeks ago #94942
surferjunkie,
WELCOME ABOARD. = NEAT G3, too.
Re:Need to identify my winter project 11 years 11 months ago #96901
  • hodgify
Have not been able to get to much done on the hull but trying to get back at it ; Worked on the trailer made bunks out of 2X6s and covered with indoor/outdoor
Re:Need to identify my winter project 11 years 11 months ago #96902
  • hodgify
another of the trailer ,had my sons and friends come over and help flip boat onto trailer ,fit great and looks like it will slide on and center itself.
Re:Need to identify my winter project 11 years 11 months ago #96904
  • hodgify
sanded the top deck with 40grit paper and spread a coat of a mixture of epoxy carbon and glass milled fibers thickened up with cabosil and spread out to cover all the cracking in the gell coat . Will smooth out and apply one layer of thin glass to make it strong enough to walk on.
Re:Need to identify my winter project 11 years 8 months ago #100686
  • hodgify
Finished painting ,installed all hardware and interior and got the motor on and running
Re:Need to identify my winter project 11 years 8 months ago #100687
  • hodgify
took it out for test run Sunday. Ran great , tracked straight and got it up to 42mph ,had no tach so I did not push it , installed tach tonight and will test some different props and this weekend , supposed to be nice here on the Niagara
Re:Need to identify my winter project 11 years 8 months ago #100699
That's an awesome feeling on the first outing after a long project, congrats on a job well done!
  • 2
Time to create page: 0.177 seconds
We have 17470 guests and no members online
